Re: F504 Diesel: What Parts To Change on a Clutch Swap?
Posted by CNKS on September 13, 2009 at 14:16:48 from (216.144.104.128):
In Reply to: Re: F504 Diesel: What Parts To Change on a Clutch Swap? posted by charles todd on September 13, 2009 at 10:44:02:
The distance between the flywheel surface and the "step" where the bolt holes are. The dimension given by Kevin is the same as the 460. The machinest is supposed to cut the step to that spec. Or, he can take the same amounts of the step as he did from the flywheel surface. The latter may not be the best way if someone previously machined the flywheel and ignored the step. The 1.188 Kevin mentioned is the same as on my 460.
