Re: Difference between Farmall H and M
Posted by john d on September 13, 2009 at 17:08:34 from (69.130.164.213):
In Reply to: Difference between Farmall H and M posted by Jack Morgan on September 13, 2009 at 16:27:41:
Starter, maybe distributor, anything electrical will probably fit, including lights and switches, such as ignition, starter, and the entire light-switch/ammeter box. Light bar, gas and radiator caps, oil pressure and temp gages, muffler, seat and throttle lever. M drawbar is heavier, but will fit the H. Wheelweights, rear rims and tires, but not the wheel centers. Front rims and tires will exchange. Fenders are the same, if you have them. Steering wheel, and the universal joint in the middle of the steering shaft. Probably the sediment bulb on the gas tank.
