Re: 2444 lowboy
Posted by IH2444 on September 13, 2009 at 18:25:02 from (74.234.147.57):
In Reply to: Re: 2444 lowboy posted by IH2444 on September 13, 2009 at 18:22:53:
oh forgot something else. If you work on the brakes use silicone to seal the druns back to the rear housing. Keeps them working a lot longer esp if they have aux hydraulic valves or sit outside.
Oil gets the left brakes and water gets the right one.
