Re: Fast Hitch Farmall C
Posted by AndrewFromNS on September 14, 2009 at 09:55:23 from (71.7.194.23):
In Reply to: Fast Hitch Farmall C posted by Carl Beck on September 14, 2009 at 08:17:13:
All the small-point implements should be the same width to fit in the C Fast Hitch. There is no way, short of heating and bending, to spread those receivers further apart then they are now.
I'll ask, though....are you sure the implement you want to insert, thats too wide, is made for your C? Implements made for anything 300-sized or larger, have bigger (wider, taller) points and that added size would make the spacing wider. Even if spaced the same, those large points would not fit into the fast hitch on your C.
AR
This post was edited by AndrewFromNS at 09:55:49 09/14/09.
