Re: 584 No Brakes
Posted by jimb2 on September 14, 2009 at 11:17:02 from (99.240.236.11):
In Reply to: Re: 584 No Brakes posted by megamc on September 13, 2009 at 20:27:58:
Hi, the bleed screws look like bleed screws on brakes on a car or like grease zerks. They are on top of each axle housing on the side of the trans/diff case. Get some clear plastic tubing and a clean bucket. Fit the tubing over the bleed screw on one side at a time, while engine is running and hytran is warn, loosen bleed screw and let drain into bucket until air bubbles are gone. DO NOT PUMP BRAKES. Close this bleed screw and repeat on the other side.
Make sure hytran fluid is topped up.
You may have to reap bleeding procedure again to eliminate all air.
Hope this will help
JimB
