ScottyHOMEy said: (quoted from post at 15:53:06 09/14/09) If they didn't change the casting too much from As and Bs, you should find jack pads under your differential for jacking the left side, and another near the outer end of the diff shaft housing (under the seat) for jacking the right side. Cross-stacked wood blocking will do the trick nicely.
I agree with Scotty. If you look under your Super A you will see jack pads under both sides. Good luck.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
