Re: Farmall H runs great but wont start with starter 6 volt
Posted by JT on September 14, 2009 at 18:44:02 from (174.156.168.184):
In Reply to: Re: Farmall H runs great but wont start with starter 6 volt posted by TractormanNC on September 13, 2009 at 16:18:11:
A mag will fire any time it is turned. I use a hand crank on by B, with a mag, and I crank it slow, then give it a flip and starts right up. I would suggest checking to make sure you have good compression, henceforth, good vacaumn to pull fuel into the engine, or loose manufold or carb mounting bolts. when you pull it, the engine is turning fast enough to create a little more vacumn than you get with starter alone. .
