Re: Farmall M - What to do
Posted by SDE on September 14, 2009 at 18:53:56 from (174.124.5.222):
In Reply to: Farmall M - What to do posted by Randy D McClenahan on September 14, 2009 at 15:50:46:
Remove a ring from the piston. Put the ring back in the cylinder. Measure the end gap on the ring. How sharp are the edges of the ring.
How often are you adding oil? You have it apart because you know you need to do something about it. You can do it right, or you can do it cheap.
I had the crank ground on mine and put new rings in it. For a little more money, I could have gotten sleeves and pistons.
Steve
