Re: Use of RTV/Silicon with water pump gaskets????
Posted by charles todd on September 14, 2009 at 19:57:56 from (205.242.95.134):
In Reply to: Use of RTV/Silicon with water pump gaskets???? posted by cfitch on September 14, 2009 at 18:57:31:
Three-Bond Sag Type silicone will replace about ANY gasket. Okuma, Club Car, and other OEM's recommend. It is grey and is somewhat runny, but not as bad a properly mixed J-B Weld. I used it instead of gaskets on my axle housing to differential, oil pan, and shiffter boss on my Farmall 504 and have suffered NO LEAKS in 3 years. Also used it exclusive as the sole gasket material on my 1979 C20 Chevrolet 350 valve covers, timing covers, and oil pan... Dry as a bone. Trick is to let it semi-cure before torquing down to prevent squeezing it all out.
CT
