Sounds good. I've pulled mine with an engine hoist so that I can pull them right away to do whatever needed doing. What you might want to do, unless you're really set up and your chain fall is on a trolley, is position it or the tractor so that the final pulls away just a few inches, 3 or 4, once you unbolt it. That's still close enough that you can swing it back in to remount it without too much trouble, and you can also lay it down on blocks (being careful to protect the pan) if you have to have it steady for any beating or pulling to replace the pin.
There is a thread just above or below this one about jacking a Super A. The jack points are obvious but, especially in this case, I favor Hugh's suggestion, if your tractor has the drawbar on it, of jacking it under the transmission and then letting it down a little to rest on blocking under the drawbar. It removes the possibility of hitting your jack with the final drive when you go to turn it around -- that could get nasty. You could jack and block both sides in that fashion, too, so you can run the tractor with the tires off the ground to adjust the brakes up evenly.
And, for sure, having both brakes working evenly is an excellent idea if you're going to be using them in road gear.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
