Re: H two way hydraulics
Posted by gene bender on September 15, 2009 at 03:42:31 from (207.177.56.163):
In Reply to: H two way hydraulics posted by David G on September 14, 2009 at 20:15:11:
Is is easy to mount on the lite bar. Hooh the pressure side to the outlet of the belley pump and the return to the bottom of the belley tank where you would drain. Get a open center control valve. Then you need to have the lift--all lever back. You can fasten it back full time. Then run your two outlets on the new valve to the rear and you now have a two-way system.
