Re: Farmall A brake replacement question
Posted by Jim Becker on September 15, 2009 at 06:27:02 from (71.252.159.128):
In Reply to: Farmall A brake replacement question posted by David Kirkpatrick on September 14, 2009 at 15:58:58:
ScottyHOMEy said: (quoted from post at 06:33:57 09/15/09)There is a thread just above or below this one about jacking a Super A. The jack points are obvious but, especially in this case, I favor Hugh's suggestion, if your tractor has the drawbar on it, of jacking it under the transmission and then letting it down a little to rest on blocking under the drawbar.
Jacking or blocking under the drawbar is out in this case. The drawbar will have to be unbolted from the final. You would be able to jack under the drawbar if you then block under the transmission and remove the jack.
