Re: Use of RTV/Silicon with water pump gaskets????
Posted by Bill in IL on September 15, 2009 at 08:59:44 from (131.43.10.190):
In Reply to: Use of RTV/Silicon with water pump gaskets???? posted by cfitch on September 14, 2009 at 18:57:31:
Never use silicone on water gaskets or any gasket. Freind of mine learned that the hard way. Put his water pump in his car filled it up and it pretty well started leaking as soon as it warmed up the first time.
If you think you need something use weatherstrip adhesive to hold your gaskets in place during assembly.
I would recommend not using any silicone in combination with any gasket. Just let the gasket do its job use the silicone where you may have severe irregularities or have to fill a hole in something.
I would may need to look into this stuff you are talking about Charles..... Have a few gaskets that I don't really don't want to have to make.
