I've had Champions that were no good right out of the box.
The Autolite 3116 is a non-resistor plug, and when used in conjunction with solid core plug wires, should provide a good, hot spark. The 386 and 388 are both resistor type plugs and CAN replace the 3116 in a distributor ignition but are not suitable for a magneto. I don't know how a non-resistor plug compares in heat range to a resistor type plug.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
