Re: SPARK PLUG - INFO HELP NEEDED
Posted by charles todd on September 15, 2009 at 14:28:04 from (205.242.95.139):
In Reply to: SPARK PLUG - INFO HELP NEEDED posted by 1965LONEWOLF on September 15, 2009 at 04:49:19:
I like NGK plugs in ANYTHING. Had a high-milage engine eating Delco plugs due to fouling in my 1979 C20 (original engine) and had even used the "no-foul" adapter, you know the one the plug screws into and has a little hole in the end. The NGK's resist fouling MUCH better than any convential plug I have used. If they make a NGK for a piece of gasoline equipment I own, it gets NGK plugs. Bar none, the best for the money.
CT
