Re: ih utility 240tractor hydraulic pump seal
Posted by CNKS on September 15, 2009 at 17:55:29 from (216.144.104.128):
In Reply to: ih utility 240tractor hydraulic pump seal posted by mark ogden on September 15, 2009 at 15:02:25:
The seal blew or it just leaks? If the latter the shaft is grooved and needs a speedi sleeve. If it has an oring for a seal, the hole for the shaft has to be enlarged to accept the sleeve. If the former the pump is probably shot. What is a remanufactured Case pump? They don't interchange with IH.
