For original 6 volts POSITIVE ground, the batteries + goes to case/frame/ground which could be the frame or a bolt where starter mounts to frame etc.........The batteries - goes to the starter switch.
Since you had it at Neg ground you may wanna first Polarize the genny by momentarily flash jumping a wire from the BAT side of a Cutout Relay over to its other GEN/ARM terminal and you should get a spark. If it had a Voltge Regulator you could polarize by momentarily flash jumping from its BAT terminal to its GEN/ARM terminal or from BAT direct down to the gennys ARM post.
If it was Pos groud and got changed to Neg ground the ammeter leads need swapped side to side otherwise it will read bass ackwards. Similar if it were a coil distributor ignition instead of a Magneto the coil leads needed swapped i.e. for Pos gorund the coils lil - wires to ign switch and + to distributor but opposite that for Neg ground.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
