Re: 826 diesel running rough
Posted by MN Scott on September 16, 2009 at 07:38:45 from (12.157.197.244):
In Reply to: 826 diesel running rough posted by REDMAN 826 on September 16, 2009 at 04:01:56:
You didn't grind the valves did you? On a German you can't grind the valves because it sets them in the head and reduces the compression enough that it will not run or start very good. The only way to do valves on a german is to replace the valves and seats to maintain proper valve height. Also make sure your pump timing is dead on as one degree either way will cause the problems your having.
