Re: WD?
Posted by Jdeit on September 16, 2009 at 14:00:52 from (216.51.181.212):
In Reply to: WD? posted by Jdeit on September 16, 2009 at 09:22:48:
Ok the only numbers I could find are, on the head 278292R1, the block I think 2123C, and the trans 8866-DE. Hope this helps...
  • Re: WD? glennster 18:51:44 09/16/09 (3)
    • Re: WD? Jdeit 08:00:38 09/21/09 (2)
      • Re: WD? Jdeit 09:18:39 09/21/09 (0)
      • Re: WD? glennster 08:14:11 09/21/09 (0)
