Re: heater for winter starting
Posted by jal-SD on September 16, 2009 at 19:13:22 from (70.57.233.182):
In Reply to: Re: heater for winter starting posted by Hugh MacKay on September 16, 2009 at 18:36:10:
I put a 1000 W tank heater on my H, used the block drain & plumbed it into the outlet for the heat guage with a pipe "T". Works OK, but the heat guage reads a little low. Don't know why it wouldn't work on an M. Look at the thermostat housing, some have a drain plug below the level of the thermostat. It probably would work to plumb it into that plug opening. (My $0.02 worth. jal-SD)
