Posted by Kevin Meier on September 16, 2009 at 19:14:31 from (208.90.10.236):
In Reply to: SMTA TA Rebuild posted by GordoSD on September 16, 2009 at 18:13:59:
I have the t/a kits (ta, ta clutch, gaskets and seals) for $800. I am suprised that a dealer isn't higher than that. Does the topshaft need replaced? Most do. If the disk has beat on it bad enough to wear the splines it's junk. Make sure in the t/a rebuild you are getting a machined carrier. Machined ramp with new rollers. New needle bearings in the sun gears, new oil seals and bearings in the carrier and I would assume if they replace the topshaft it also gets a new bearing installed. Kevin
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
