Re: gear grinding
Posted by Janicholson on September 16, 2009 at 20:56:42 from (64.61.211.44):
In Reply to: gear grinding posted by tackhammertime on September 16, 2009 at 19:04:52:
If the pedal to platform freeplay is at an inch to 1.125" the adjustment is fine. If it will not slow down to enable a clash free shift (wait 10 long seconds) the pilot bearing may be dragging, or the disk might be warped. The test is to put it in any gear, then with the clutch pushed in, take it out of gear. Keep clutch in all the way. If it is then taken out of gear (clutch remains in) for 10 seconds does it grind. If so it is dragging. If not it is pretty normal. There is no syncro in these units at all. If the gear oil is low (or thin) it will allow the gears to coast too long, check that as well. JimN
