Re: gear grinding
Posted by Hugh MacKay on September 17, 2009 at 01:46:22 from (216.208.58.98):
In Reply to: gear grinding posted by tackhammertime on September 16, 2009 at 19:04:52:
When you get on running tractor, or as you describe have it in neutral with clutch out, depress the clutch, hold the shift lever opposite reverse, as if you were tryin to put it in the gear that is not there.
I'm not sure about the A, but it stops transmission in SA, 100, 130 and 140. Try it and let us know the results.
