Posted by Tom 43 on September 17, 2009 at 11:43:48 from (70.143.51.131):
In Reply to: Worn distributor posted by Bill in IL on September 17, 2009 at 09:29:09:
When does it miss? Put a timing light on it and see if the marks are steady. There should be no centrifugal advance at idle, so if the mark is steady at idle your miss is elsewhere. See if the bushings on the shaft are worn. There should be no radial play. See if each lobe of the distributor cam opens the points an equal amount.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
