Posted by D Slater on September 17, 2009 at 13:21:40 from (71.164.37.9):
In Reply to: Worn distributor posted by Bill in IL on September 17, 2009 at 09:29:09:
Yes, if you can make the pins. Remove the shaft from distributor and make pins a light press fit and swell them at bottom after installing. If there loose you can braize them at bottom, I have also carefully spot welded them in on bottom side and smoothed up. If the weight holes are oblong drill to next size and make the pins bigger where weights swing to match. You can buy a new shaft with the pins but around $150.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
