Re: IH Mounted Sickle Mower
Posted by agpilot on September 17, 2009 at 15:30:43 from (206.146.78.170):
In Reply to: IH Mounted Sickle Mower posted by farmallmechanic05 on September 16, 2009 at 19:25:24:
Hey farmallmechanic05: I will offer this warning. I bought one 3 years ago and used it maybe 4 hours and had the right axel housing start leaking tranny oil. If you stand several feet behind it and in line with the right mounting bracket and the sickle bar is raised a foot up, you should see that most all of the weight is balance on that right mounting bracked. That means the right cast iron axel housing takes most all of the load. Got bumpy ground then add extra stress to the right axel. If your seals are newer then it may not leak right away. Just my luck with this model. Not worth fixing. Easier to just buy another type with trailing wheel to hold up the mower weight. ag
