Posted by Dave Eklund on September 17, 2009 at 16:49:52 from (66.65.245.252):
In Reply to: Re: ud9 motor posted by D Slater on September 17, 2009 at 06:12:07:
Thanks for the reply can I still get the felt for the seal and I was told when I change the pump i will have to change the injectors to because the line are different and the fitting on the injectors are different I might have left a number off the serial # think it is udcb 21252
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
