Posted by Pale Rider on September 17, 2009 at 18:00:32 from (207.200.116.5):
In Reply to: gear grinding posted by tackhammertime on September 16, 2009 at 19:04:52:
The solution is deceptively simple. I'll bet if you push that clutch in and hold it for a minute then try shifting, the gears won't grind. If you have a belt pulley or a power take off that is engaged you can actually see the motion come to a stop. That's because you are breaking the link and allowing the momentum of the transmission to slow to a stop.
What's going on there during your typical shifting attempts is that when in neutral the clutch no longer fully disengaged. There isn't enough contact by any stretch to move the tractor but there is more than enough to get the main shaft in the transmission spinning while it is not engaged to any gears. As it spins thusly and you try and engage a gear you're going to create all sorts of noise and grinding as you force the thing to lose it's built up momentum and stop spinning by the friction your gears create while grinding away until they stop moving enough for the teeth to mesh and engage. It's definitely not good for your gears but assuming you have clutch adjustment, easily addressed. Simply adjust it so that it gives the effect of more clutch resistance and thus travel earlier on as you push in on the pedal. It would be too confusing for me to try and call this "in" or "out".
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
