Make 2 dowel pins from long bolts to put in each side of frame rails and into clutch housing before all bolts are removed. Split just enough to put part of bolts with nuts back through frame rails and engine rear plate, then finish spliting with the stands on frame rails. If it has the solid front engine mounts one or 2 bolts a side will do. If it has the early type rubber mounts put 2 bolts a side back in. Remember to remove starter and bolt behind it. You can get to seals without spliting though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
