1955 farmall idles at 900 rpm after rebuild
Posted by Brion on September 17, 2009 at 20:21:54 from (24.179.170.86):
This tractor was leaking gas through the carb before I rebuilt the carb. After rebuilding, it runs fast at idle and gas came out of the air intake hose. Adjusted float down a little and the gas quit coming out of air intake, but still runs fast at idle. Carb has a adjustable main jet on bottom of the side of the bowl(not on the bottom of the bowl) and a adjustment screw at the top by the throttle plate(this screw only makes a difference if I pull it all the way out). The idle screw is turned back so I know it is not touching the cam lobe. I do not have a diagram of this carb and could use one if anyone knows where to find one at.
