Re: H tranny oil
Posted by randy hall on September 18, 2009 at 05:52:18 from (209.143.0.64):
In Reply to: H tranny oil posted by Mike CA on September 18, 2009 at 00:25:19:
i use 140 weight gear oil in these old tractors. it won't leak out as easy as ninety weight. in a cold climate it will be a little stiff, but usually the old tar like stuff you drain out of an old tractor rearend is thicker yet.
