Posted by ScottyHOMEy on September 18, 2009 at 07:21:49 from (64.222.247.18):
In Reply to: Super A Running Hot? posted by Pete 7 on September 18, 2009 at 05:50:52:
If you're running straight water, it will evaporate some, but I suspect the level that it's falling to is it's natural level, as there is just about a quart's difference between the top of the neck and where it will settle down to on its own.
You couldn't rule out a crack in the head or a bad head gasket that's letting some of your coolant get into the cylinder and burn off as steam, but you should be noticing the steam (as white smoke) if that's the case. If it's running right, I'd consider this the last thing to look at and only when everthing else has been eliminated.
I'd try draining and refilling with 50/50 antifreeze and water and see if it drops down to one level and stays there without overheating.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
