Re: How long will an H run?
Posted by dhermesc on September 18, 2009 at 07:38:56 from (24.248.193.103):
In Reply to: How long will an H run? posted by Mike CA on September 18, 2009 at 00:31:13:
As noted by Ed below they burn two gallons an hour under "full load" - meaning under hard pull with governor giving it all she can handle - essentialy how you'd run while hooked to a plow.
Under light load - like what you are using it for it probably burn half or less that much fuel. The fuel tanks holds 17 gallons and we could easily run our H (with indifferant tune) for 12-14 hours a day while putting up hay with a 9'sickle bar mower or a 5 bar rake with only morning fill ups.
