Re: super m carb and distributor
Posted by Bob M on September 18, 2009 at 08:37:45 from (151.190.254.108):
In Reply to: super m carb and distributor posted by jdetig1 on September 18, 2009 at 07:48:08:
The carbs are identical. The 450 carb MAY however have a slightly larger venturi insert - I'm not certain.
Only way to adjust timing for absolute max power is to set it while observing output on a dyno.
Otherwise set it per the owners manual or a degree or two advanced using a timing light.
But if a timing light shows the timing is "dancing" randomly more than a couple degrees at speed, find and correct the cause. Otherwise you're just chasing your tail trying to optimize spark timing! (Look for worn distributor shaft bushings, gears, centrifugal advance, etc.)
