The only manual that will be any diffeent between a B and BN would be the Owner's Manual, and the only difference between them will be in the chart for setting the width of the rear wheels, as that was the only functional difference between the two tractors. The differential shaft housings on the B are about 22" wide on each side; on the BN they're 18", making the whole tractor 8" narrower, hence the N. Either tractor came with either the two wheel narrow front or the single wheel.
They are essentially the same machine and all the other manuals cover both, along with the A. You'll see when you get into the parts catalog --the BN seat platform and pedals are the same as an A, but the B, being wider, has a wider platform, a separate support for the right side of the seat and one longer brake shaft.
All three have the same motor and transmission - the differences in them all have to do with their running gear -- A is offset wide front with a unique steering gear and different front implement mounting, B and BN are identical to each other in everything except items that relate to their width, like the seat platform and drawbar.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
