Re: super m carb and distributor
Posted by Tom 43 on September 18, 2009 at 09:33:33 from (70.143.51.131):
In Reply to: super m carb and distributor posted by jdetig1 on September 18, 2009 at 07:48:08:
Bob M and jaybird are giving you excellent advice. Check for wear in the bushings and centrifugal advance mechanism(worn pins, hole in the weights, springs). I believe the factory advised recurving the distributor which actually retarded timing when the higher compression fire crater pistons were used. SET TIMING TO FACTORY SPECIFCATIONS! IH paid a team of engineers a fortune to figure out optimum timing and rate of spark advance.
