Farmall Tractors Discussion Board
Re: Need suggestion or hints on putting rear seal on super c crankshaft
Posted by Curt Cooke on December 28, 1998 at 18:58:05:
In Reply to: Need suggestion or hints on putting rear seal on super c crankshaft posted by Jim Smith FT wayne on December 28, 1998 at 18:39:23:
Jim, it's no big deal but easiest with two people. Split the tractor, supporting the engine and blocking the front wheels. Then gently push the rear of the tractor away from the front (best have the rear of the tractor supported too). As far as lining up that clutch in the absence of the "proper" tools, use a long bolt that comes close to the size of the pilot bushing in the crank. Before retightening the pressure plate to the flywheel, run the bolt through the clutch disk into the crankshaft, get it close as you can to "lined up". While mating front and rear, engage the PTO and turn it until you can't because of the engagement of the input shaft in the clutch disc. Bolt her together and you're done.
Post a Followup
: Re: Re: Need suggestion or hints on putting rear seal on super c crankshaft
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
