Posted by ScottyHOMEy on September 18, 2009 at 20:26:18 from (70.105.229.48):
In Reply to: Hauling a cub posted by Dave H (MI) on September 18, 2009 at 19:26:15:
Lucky you!
Evenin' Dave.
Lots of guys bind down that way. The important thing, any way you chain it down, is to stop after about ten minutes into the trip and periodically thereafter and make sure ALL the chains are still tight.
I'd probably put the Cub on nose first to keep the weight on the high side of the trailer, and use the longer chain to secure by the front axle tube. Run one end of the chain through the anchor pocket and bring it back up, over one end of the axle tube and hook it back onto itself. Do the same thing at the other end of the axle tube with the other end of the chain. Hook each end so they are about even as this is the end you'll pull (or push) against. Any excess chain will be between the two loops. Tighten that up, and then use the binder on the chain on the rear.
Fixed drawbar or 3-point? If fixed, the drawbar is the place to tie onto. I think it has only a single hole, and I wouldn't trust a single clevis, so it's probably best to give your chain an extra turn over the drawbar. Pull it up as tight as you can by hand on one end and put the binder on the other.
Four anchor pockets doesn't sound like many. Keep in mind that you can run your chains under the tractor if you need to instead of off the ends. See Bouncer's lashing job at the link. That might be useful depending on where your anchors are, and it might also open up some options for finding a place to tie onto the rear if the tractor is a 3-pt.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
