I'm assuming you're asking about valve stem seals, and your guess is right. It did not come with them originally and there would not normally be any in a gasket and seal kit for a motor rebuild.
I'm wondering if in shopping you saw two kits, one normally called a valve kit (basically just a head gasket and a valve cover gasket, maybe a gasket for the water outlet, but no valve stem seals) and an overhaul or rebuild kit, which would include pan gasket, front and rear main seals and all the assorted fiber gaskets for water pump, etc. . . AND everything that would be in the valve kit.
That said, I've had valve stem seals put on both my heads when I had them off. Sort of a can't hurt might help touch in my view.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
