There not exactly the same, Its a tight fit, but rear part of clamp will usualy squeeze in the slot in a H axle housing. Most M had the front square tube that was pretty square on the corners and won't go in a H axle slot. If its got the ones like they started using about the time 400 tractors came out, they are more rounded on one side and will usualy squeeze in slots. M has 7/8 inch diameter clamp bolts and H has 3/4.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
