Re: 560 Diesel Smokes At Start Up
Posted by Jeff Z. on September 19, 2009 at 10:05:15 from (74.76.3.113):
In Reply to: 560 Diesel Smokes At Start Up posted by higgi1951 on September 19, 2009 at 09:09:09:
That is pretty normal. A diesel engine works on heat from compressed air. The white smoke is unburnt fuel because the cylinders have not heated up enough to make a complete burn.
Once the cylinders are hot the white smoke should stop. In the winter it will really put out the white smoke at start-up.
