Re: 240 hard starting
Posted by IH fan on September 19, 2009 at 18:46:35 from (70.254.28.73):
In Reply to: 240 hard starting posted by IH fan on September 17, 2009 at 19:53:30:
First thing I checked was the points. They were burned slightly, but I've seen a lot worse... didn't do anything to them. Had a little moisture in the cap and the top of the rotor was burned like it wasn't making a good connection with the center of the cap. Cleaned that, sprung it up a little and dried the cap. Tractor fired right off, but not sure if I really did anything or it was coincidence because I had the tractor running yesterday. Maybe if it sat a few days it would be hard starting again. I was also able to throttle it right up, which I couldn't do before.
This post was edited by IH fan at 18:47:49 09/19/09.
