Re: I found the manual
Posted by Hugh MacKay on September 20, 2009 at 03:51:17 from (216.208.58.164):
In Reply to: Re: I found the manual posted by Retcol on September 20, 2009 at 02:46:26:
Retcol: You should do this, probably half turn at a time and seeing results of each half turn. IT does say, "Do not turn bumper spring screw in too far as it will interfere with the low idle speed adjustment."
I was right on linkage adjustment between governor and carb, and IT seems to be suggesting this should be correct before adjusting bumper spring or high rpm limit.
