Posted by aquanosis on September 20, 2009 at 05:27:35 from (67.241.20.22):
I decided to replace my 10SD with a 10SI for ease and availability. It was only $49 at NAPA though they will no longer take an 10SD core. I'm still a bit confused about the diode that should be hooked to the #1 terminal. I couldn't get the 3A /100PIV diode suggested by Janicholson at Radio Shack because they only carry 3A / 50PIV , 3A / 200PIV or 3A / 400PIV diodes. I decided to order this one from Jameco: DIODE, SILICON CONTROLLED RECTIFIER (SCR), 1N5401, 3 AMPS, 100 VOLTS, DO-201AD Rectifiers. I'm not sure if this is correct since it's a rectifier diode. I've also seen on article 195 to use a 10ohm 2watt resistor. Should I use one of the other Radioshack diodes, use the rectifier diode I got from Jameco or get a resistor from somewhere else and what part number and where. I'm sure this is much less complicated than I'm making it. Thanks
This post was edited by aquanosis at 05:28:26 09/20/09.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
