Posted by scot in pa on September 20, 2009 at 06:55:07 from (68.25.232.212):
In Reply to: Re: 1466 clutch posted by f826 on September 19, 2009 at 18:41:42:
The hydraulic booster is just like a wheel cylinder, in the rod between the pedal and the lever for the throwout shaft. Some bolts, hydraulic line or two, and it pops right off. May have to pull a battery or something if you have the factory cab.
If you have something without the booster, 06-66 series, compare the clutch linkage and you will find it quickly.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
