Temp. gauge route
Posted by achodges1 on September 20, 2009 at 15:33:06 from (66.139.216.136):
I am putting a wireing harness and new gauges on a Super-C. Does the temp cable route the same as the wireing harness,under the battery box,through the channel under the touch-control,over the clutch,and along the head?
