Hello Haas, Thanks for your picture and brief examination. Is it possible to buy a photo copy of your literature? Are your colors correct? Mine shows green in several locations. Is your hopper original? I need to build one as you can tell and would like measurements. Could you tell me what the purpose of the spiral gear is that is integral with the flywheel hub and also what the casting is used for on located above this spiral gear? I do not have the back bearing support bracket either, could you send a larger picture to my email so I can look that over. I will need to build that item. Is that support bearing supposed to function as a thrust bearing? Do you have an approximate age for these machines? I plan to run mine off my J-D A, until I can find and rebuild a 6 hp hit and miss. Thanks for your time.... Al (alsfarms@hotmail.com)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
