Re: 806 hyd valve question One way cylinders
Posted by pete 23 on September 20, 2009 at 18:40:58 from (173.87.8.73):
In Reply to: 806 hyd valve question One way cylinders posted by railhead on September 20, 2009 at 18:05:33:
806 should work fine on a one way cyl. Use the outlet that will lift the one way cyl when you put lever into the forward, (down position), and then to lower cyl put lever way down into float position. Only reason this won't work would be a coupler problem, check valve block in system or load on cyl not enough to lower itself. You can leave in float position when down if your equipment is positined where you want it to be and then just flip lever back one notch to raise.
