Re: I think I goofed. Belt pulley problem...
Posted by Mike CA on September 20, 2009 at 21:23:22 from (99.28.152.102):
In Reply to: I think I goofed. Belt pulley problem... posted by Mike CA on September 20, 2009 at 20:40:46:
Wayne, that was very thorough, but way too deep for what I want to do. What I took from that is pull the shaft out, remove the shields and clean up the bearings, put it back together and put some silicon on each of the shims at re-assembly. The silicon will keep it from seaping oil?
