Posted by Owen Aaland on September 21, 2009 at 02:38:34 from (65.161.86.32):
In Reply to: 1086 problem posted by 728171 on September 20, 2009 at 07:28:36:
jim 7 said: (quoted from post at 10:28:36 09/20/09) I have anti freeze in the oil pan of my 1086.I replaced the head gasket,checked and tested the oil cooler. when i put anti freeze in the engine,the anti-freeze ran down inside the number two cylinder. any ideas what the problem is?
Coolant coming down the inside of the sleeve on these engines is almost always due to a hole in the sleeve caused by cavitation. These holes are usually in the lower part of the sleeve on the thrust side. With the piston all the way up you will probably be able to see exactly where it is leaking.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
